Hello everyone, I am new to this forum and need some help in understanding phd2 logs generated by ASIAir and how to make necessary adjustments, I once posted in one of the thread where people were calculating durations according to their PE graphs for AM5, after wandering that thread, I am here to understanding guide settings first.
So this is my current equipment:
Mount: AM5
Imaging camera: ASI294mm Pro
Telescope: Redcat 51 II
Guide camera: ASI220mm mini
Controller: ASIAir Plus
Focuser: ZWO EAF
Filter wheel: EFW w/ narrowband filters
When I started with this mount, I had the ASI120mm mini as the guide camera and I am seeing an improvement in RMS when I upgraded to the 220mm mini.
I live in Bortle 8-9 area and use narrowband filters for imaging.
I calibrated the guiding near the celestial equator (on the star Altair), but I don't have a good view for declination, I have heard that you should calibrate guiding near the intersection of Meridian and Celestial Equator? Please correct me if I am wrong, here to learn!
Ok so coming to the problem I'm facing, with the new guide camera I saw a drastic improvement in the RMS, around 0.4", I've also seen 0.3" at times which I really didn't expect, but then after some time, the guide star drifts away.
I probably might be using the guide camera FL incorrectly as well, I set it to 200 and I think it should be 1/3-1/4 of the main imaging telescope.
I have attached 2 screenshots as well, the drift in those is not visible that much, but at RA and DEC Aggr at 30%, the star drifts towards right top (or reticle drifts bottom left) gradually very slowly, I think these details are there in the log but that's what I remember from the session.
I want this to be my lack of knowledge and not the mount itself. I haven't actually tried Phd2 yet for guiding but that's the next thing, and I am currently going thru the docs. I believe Guiding Assistant from Phd2 might help as well. I'll also try using the drift alignment to see if I have PA issues.
I also did the Polar alignment 3 times, just to be sure, for the first two times I noticed the error re-appeared, and looked like I tighten the knobs way too much. So for the 3rd attempt I just tightened them as needed.
Edit:
After I see the star drifting from the guide square, I see a lot of star trails in the images (not particularly in the same direction), one of which looks like the following;
![](https://bbs.astronomy-imaging-camera.com/assets/files/2023-06-16/1686945207-308228-screen-shot-2023-06-16-at-125253-pm.png)
![](https://bbs.astronomy-imaging-camera.com/assets/files/2023-06-16/1686943772-316405-img-0157.png)
![](https://bbs.astronomy-imaging-camera.com/assets/files/2023-06-16/1686943773-23195-img-0159.png)
