This is the first time I tried Video mode since the last series of updates and it is screwed up. I cannot change the resolution. It is stuck on 480P. There was a spot under the start video button where you could select the resolution, but that is gone. In the very top right of the screen I can see part of the assigned resolution, but only a small part of the bottom, too small to access. When I first tried the Video mode, most of the screen basically turned white. I was on the Moon at the time with a setting of 1ms. Everything was fine in Preview mode. I have restarted several times. The display is fine now except for the missing or misplaced video resolution setting. I am using an iPad Pro 11" to run the ASIAIR Pro. What can I do?
JohnD
