I just got my ASI533MM-Pro this morning. I have it set up with the filter wheel and ASIAir Plus. I've got the ASIAir powered by a generic Walmart 12V universal power supply, which is connected to the camera. I used this same power supply with my ASI2600MC-Pro without issue. But with the ASI533MM Pro- I keep getting a "low power" message on the app, and it won't cool beyond 34%. Is this a power supply issue, or is something wrong with the camera? When I get home, I will have the ASI533MM- Pro, 8-position filter wheel, AsiAir Plus, and ASI EAF all being powered from the same 5amp 12V power supply. Will that be enough? Thanks!
