I am new to the field of astrophotography, and I have a couple of questions about achieving the correct back focus. I'm thinking I need to get this right so I can rule this out. Mainly interested in capturing the Moon, Jupiter, and Saturn. It's 12.5 mm to the sensor; the nosepiece( 28 mm) and a ZWO duo band filter (5 mm) add another 33 mm bring the total to 45.5 mm. This leaves 9.5 mm. So, would I need an additional 9.5mm of spacers to achieve the correct back focus distance of 55mm? I will be connecting to an Astro Tech field flattener for an AT 115 EDL.
Also have Celestron 9.25 XLT with a 0.63 reducer installed. Back focus is 105mm. Do I add some additional spacers to my image train to achieve the correct distance? Looks like I would need an additional 60.5 mm to reach the correct back focus here.
Hopefully, someone can let me know if I am on the right path here. Thanks in advance
