Hello!
I am using an older (no WiFi) Star Adventure with the ASI Air Plus, 120mm for guiding and modified DSLR.
Is it possible to plate solve and do the automated polar alignment even though my mount is not a go-to?
Thank you for your time!
I read somewhere that it becomes a manual process. You plate solve, note the coordinates and adjust. You keep doing that until your target id centered.
stubblejumper
Gotcha! I’m assuming it’s the same process for polar alignment?
