If you want the ASIAIR to automatically center when your mount is not perfectly aligned to the sky, you need to enable the "GoTo Auto-Center" switch in Mount Settings.
Otherwise, just manually plate solve after the initial GoTo, tap on Sync And GoTo, rinse and repeat until you are satisfied with the error.
