Hi Everyone
Instructions / Settings for Connecting an ASIAIR Plus to a AM5 mount
Did all the things in the video - https://www.youtube.com/watch?v=w6OQVkAB1UM Unboxing and Setting up the ZWO AM5 Strain Wave Drive Mount
But the settings don't work and mount won't connect via Wifi - works OK via USB on Serial
Cheers Fletch
AstroFletch You may share some setting screenshots with us, can you connect AM5 in the ASIAIR app successfully?
I succeeded in connecting wired AM5 with ASIAIR Plus with the setting shown in an attached photo. However, I can’t connect them wireless. How should be the setting of ASIAIR Plus? Thanks in advance.
zuts
Weekend-stargazer Upgrade to the newest version AM5 and AM5 HC firmware to try.
Hi, I also have this issue. Can connect asiair plus to am5 with usb from plus to mount. Cannot connect wirelessly?
I am setting it to serial, should i try ethernet and if so what ip and port
This worked for me: If you click on the info button at the end of selected AM5 mount wifi shown at 2:05:41 in the video you can get the ip address. On mount settings change from serial to ethernet. Enter the ip address obtained above in the settings. I used port 4030 & UDP.
@tech@zwo#57033 As soon As I updated the firmwares of AM5 and the hand controller, I succeeded in connecting AM5 and ASIAIR Plus finally. Thank you!
