Bob_Gardner This amounts to 31 + 17.5 = 48.5mm, or 4.5mm longer than than the 44mm back focus distance required by Canon FE lenses
Bob,
The ZWO adapter should come with a detachable 5mm spacer. The one that I use for my All-Sky camera (Samyang Fish-Eye) does.
Remove that spacer before you use it with cameras that have 17.5mm flange distances. Include the pre-mounted spacer only for cameras with 12.5mm flange distances.
After removing the spacer, the adapter that I have is about 26mm thick. Measure 5mm from the T2 end of your adapter, and you should notice the seam of the spacer.
You may also need different shims when you use the adapter with or without a filter. Delrin spacers come with the ZWO adapter, but you may want to get stainless steel M42 washers.
