- Edited
ckoos when the "temperature" falls from 25.2 to 17.7. Then again when the "temperature" rises from 16.3 to 22.8. Is that actually happening
The problem is that because of the cheap (undithered) DAC in the EAF, the EAF readings wil be oscillatory once you are in the 23ºC to 26ºC range (see original post by @SamoL). This will cause every frame to run through the autofocus routine if the delta is set less than 3ºC.
For what its worth, I need to refocus once every 0.5ºC on the FSQ-85 to take advantage of its very small spot diameter.
I also blind-refocus based on the actual temperature change. I.e., change the EAF step position based on temperature ∆, without trying to recompute a new V-curve (the ASIAIR has no provision for doing that, but most real programs do). It is practically impossible to do that in summer with ZWO's EAF without moving the bug out of the way (e.g., adding a 10 kΩ resistor).
