gutaker Can someone, @w7ay maybe, archive the newest ASIAIR 2.0.0 Beta "macOS" app into zip file and share somewhere, just to see if, and maybe how, it works under macOS Ventura Beta?
Sorry, no can do, Patryk. Just like any other apps, only the owners (and Apple, obviously) can legally distribute copies.
This is why iMazing does not let you (easily) share an ipk file between two iPads, even if the owner of the two iPads is the same person. I think that is so they don't incur the ire of Apple.
Astrobert Plate solving works in preview but no longer in Polar Alignment.
Check the different exposure value (exposure time and gain).
Hint: before you start guiding, it is best not to increase the exposure time beyond two or three seconds. Instead, increase the gain of the camera (especially now that you can add an extra 20 dB of gain for the ASI2600).
The reason is that any elongation of the stars will cause star detection to fail, and thus cause plate solve to fail. I see a lot of the Facebook crowd complain about not being able to plate solve, and instead of increasing the gain, the usual "advice" is to increase the exposure time (snicker).
Once guiding is started, however, star shapes should allow you to use longer exposures, but be sure to turn guiding off before you apply "sync and goto" after a plate solve -- the mount would either not move, or locks up and requiring a mount reboot :-). Not a problem with polar alignment, since you are not moving the RA and declination motors.
Remember to change the gain back after polar alignment and plate solves :-).
    Astrobert
    I use the PAA from EKOS. Works very well for me. Once the PA is done, I do all the imaging on the ASIAIR.
      @gutaker
      I said: Sorry, no can do, Patryk. Just like any other apps, only the owners (and Apple, obviously) can legally distribute copies.
      If you can get explicit permission from ZWO, I can place the macOS app on my server. Without that, I would have to respect ZWO's intellectual property rights.
        w7ay I have a better idea since I dont think I can get the permission. I'll install macOS Monterey on a partition, on an external drive and fetch it from there 😉
        I had written (first post in this thread):
        We appear to have lost the ability to step the EAF by Fine and Coarse steps with arrow keys in the v2.0.0 Beta (Build 30, firmware 10.08)...
        The latest 2.0.0 Beta now shows the EAF up/down controls when you tap on the [+] icon in the Preview window. That icon used to take you directly to the aufo focus window in the older beta.
        No need to go through the Focus window anymore to get the EAF up/down controls.
        Another thing changed in this latest Beta.
        The "Reset Progress" button is no longer at the bottom left of the "Shooting Schedule" window for AutoRun. There is now a "rotating arrow" icon (Unicode 0x02941 -- official name "Clockwise Closed Circle Arrow") the top right hand corner of the "Shooting Schedule" window. Tap on that, and you are asked to confirm if you want to stop the auto run sequence(s).
        w7ay
        Thank you for clarification! 🍺
        Nevertheless, I haven't changed my process. In the former Beta everything worked like a charm. Within the current version I can plate solve a preview picture (2s, 120 gain) and it recognizes let's say 120+ stars (nearly darkness). In PA I have the same setup and it does not recognize more stars than 5 (failed). My believe is that something within the last fix (missing FOV) has some negative impact on the PA functionality. The ZWO techs seem to work on it. At least I hope so.
        Kring
        I must say that I agree 100%. I really dislike that I need to sign in to upload errors and logs. AND I have a bad feeling about the content of what is being uploaded. A clarification from ZWO is much appreciated. The privacy statements are not really helpful.
        Obs30
        The initial bug has been fixed. But in the fixed version the PA does not work any longer.
          Astrobert Interesting! How does your setup look like?
          I have an Avalon Instruments M-Uno mount controlled by the new StarGO2 Pro (SG2) controller. The SG2 is an aluminium case containing the motor controllers and a Raspberry Pi 4B. The SG2 Pi is running a local INDI server and drivers for the mount, the motor controllers and the INDI SkySafari driver.
          The mount and the ASIAIR Pro are both connected with ethernet cables to a satellite of my home wifi mesh. Since both Pi's, the ASIAIR and SG2 are using the Pi 4B, their local built-in 5GHz wifi is too weak to actually work with them efficiently. Therefore, they are set-up with the wifi mesh.
          Now, what I would love to do, is to use the native INDI driver of the mount on the ASIAIR. So far I was not able to do that. Both ZWO and Avalon looked into this and only found the current following work around: Using the SkySafari driver on the SG2-Pi by choosing the "LX200 Basic" on the ASIAIR (IP address of the SG2 and port 9624). The LX200 Basic driver does not provide the INDI Guide commands, but can slew. The guide commands are required for polar alignment and ... guiding, obviously ;-). So I can neither use guiding nor PA on the ASIAIR.
          KStar/EKOS, PhD2 and other INDI based tools, however, can access any remote INDI driver. Now I can either start KStars/EKOS on my MacBook Pro or I ssh -X pi@IPaddress to the SG2 and start the remote KStars/EKOS on the SG2 with the windows popping up locally on my MacBook through XQuartz (hence the -X option). It does not matter which or where I start KStars/EKOS, I just have to provide EKOS the correct IP address of the SG2 INDI server and it finds the native driver for the mount automatically. I connect my ASI camera to the SG2 Pi, run the PAA in EKOS and once its finished, I plug the camera back into the ASIAIR.
          The guiding camera is connected to the SG2 Pi and I access it remotely from my MacBookPro via PHD2 and its local INDI client.
          Now this sounds all very complicated, but it's not, since everything is running on the same MacBook now. Either via Terminal window or locally and connecting to the INDI servers and apps on either the SG2 or ASIAIR.
            Astrobert The initial bug has been fixed. But in the fixed version the PA does not work any longer.
            Unfortunately, as explained above, I cannot test this with my set-up.
            Obs30 Now I could do all of this with StellarMate or EKOS, but the ASIAIR GUI is so much nicer and easier to use. And more stable as well.
            The new UI design is slick. Much better use of screen space.
            6 days later
            Build 39 of ASIAIR v2.0.0 Beta now allows you to tailor the size of the GUI. (Display Zoomed in Personalized Settings.)
            At 125% zoom, you no longer have to use your pinky or the Apple Pencil to change the Slew Rate slider on a 12.9" iPad, for example. And you can once again read the RA and Declination values.
            The images in the windows are not zoomed, just the GUI elements. For example, a camera Preview image remains a constant size that is independent of the Zoom level. You had always be able to pinch zoom the camera image, and you continue to be able to.
            I found the 125% Zoom to be quite comfortable with a larger iPad, while the original 100% was squint-city. Ditto on macOS with a Mac Studio Display set to the next higher resolution from default.
            150% could be useful if you have poorer eyesight, and also to be able to more easily read the Polar Alignment numbers, which almost require magnifying glasses at the (original) 100% Zoom.
            The ADU values are now also easier to read at 125% Zoom. I literally had to use a magnifying glass with the earlier Beta. The icon to tap on for the planetarium appears to have also shrunk a little from a more squarish rounded rectangle to a skinnier one, which is good news for those of us who don't use it .
            The App icon has also reverted back to the icon used in ASIAIR v1.9. I remember someone complaining about the messy looking app icon in the two earlier v2.0.0 betas.
            The ASIAIR Zoom behavior works well too in macOS.
            IMHO, definitely a better GUI experience than the two earlier betas, especially on macOS, where you have no ability to change the ASIAIR app window size.
            Seems like it’s getting close. The last two major items that have to be fixed are no landscape mode, especially frustrating on iPads that live in landscape.
            And the need to understand the security you are putting in place and how the social aspects will be policed and kept clean. It’s best to share proactively how you will secure and manage then stay quiet and let smart users figure out if there are massive security issues or the social aspect get taken over by hackers and you have a mess on your hands.
            overall, great job on 2.0 - finish strong!
            one last minor thing, you still have not disconnected the crosshairs. The crosshairs should be part of the UI, not painted on the picture. When you zoom the photo the crosshairs should stay the same (attached to UI), not that the crosshairs zoom along with the photo
            • w7ay replied to this.
              Kring When you zoom the photo the crosshairs should stay the same (attached to UI), not that the crosshairs zoom along with the photo
              It is correct as it is.
              The crosshair should always be centered at the precise center of the photographic plate (i.e., the optical axis of a collimated system).
                w7ay It is correct as it is.
                When it was first introduced it wasn't like this. The crosshair stayed in center of screen no matter what you did with picture. I could zoom in on particular detail or star anywhere on picture and put it on center of crosshair to check drifting between subs for instance. I liked it better then. It actually had purpose for me. They should at least implement two options for each purpose.
                Andrej
                w7ay I’m not saying to not maintain center… it should always be centered.. but the crosshairs themselves shouldn’t expand as you zoom into the picture, they shouldn’t get thicker. They are painting the crosshairs literally pixel for pixel onto the image. That’s not proper UI design and it makes zooming in for precision not possible.
