darkmatter all it can do is slew - no goto, no guiding, just basic tracking and slewing
Like the EQMOD (which is also just a dumb motor controller), any GOTO and meridian flip is done by the software driver, and not by ZWO's code in the ASIAIR.
If you want to pre-stage the flip (I do that all the time), simply tap on the RA field of the GOTO target and reduce it by 1 hour (assuming the actual target is within 1 hour of transiting). Then tap GOTO. The mount should now meridian flip to the temporary target.
You can even home in on the temporary target with plate solves and syncs, so that the next step is accurate right of the bat, and saving a lot of time.
Now chill out until the original target has transited past Meridian, then go back to the RA field and set the RA back to original. After changing the RA back, execute a GOTO.
Since the target is now on the correct side of the pier, the mount should go directly to it without performing yet another meridian flip -- if it is just 15 degrees off, this GOTO should be very fast too. And if you had earlier plate solved and corrected for mount leveling, may not even need to be plate solved and sync'ed again.
I do this (pre-staging meridian flips) all the time when I use ASIAIR because I don't use any of the "auto" functions (just did it for the Cygnus Loop last night, in fact).
