hopskipson I'm looking for a sensor around the size of the IMX178
For good IR sensitivity, perhaps check out the IMX678 based cameras. The ZWO ASI678MC uses it. Albeit, smaller pixel size than the IMX178, if that is a problem.
If you can tolerate a smaller sensor, the IMX462 (e.g., ZWO ASI462MC) is really good at IR too. Has larger pixels than the IMX178, if that matters.
For UV, I have not seen any data below 400nm, though, but you can see the data down to 400nm for the above two sensors:
https://www.framos.com/wp-content/uploads/FSM-IMX678_V1A_Datasheet_v1.0d_Brief.pdf
https://www.framos.com/wp-content/uploads/media/pdf/64/76/d0/FSM-IMX462_-V1A-_Datasheet_v1-1c_Brief.pdf
Looks like there may be some sensitivity below 400nm for both of them.
