Suddenly the camera stops responding and it doesn't return an exposure. I am using Voyager and automated sessions for all nigh imaging and it ruins my imaging sessions. But this is not happening all the time. Some sessions are completed without error. I have tried with different USB cables. It happens connected through the Native Driver and through the ASCOM driver. There is no error pattern.
Julian
jalonso Could you test the camera in ASIImg, can you reproduce the problem? If possible, please refer to this guide to catch the sdk log, and then send it to us for analysis.
Thank you for your quick answer! I have enabled DebugPrint in the registry and run some daytime test sequences using Voyager but it didn't fail. I confirm the log is populated. I will try tonight with a real nightime session. I will get back to you with the results.
Last night session failed again. I am attaching the log file. Check exposure errors from 02:35:31. The session had two sequences. First sequence was completed. But the second one failed from the first exposure.
jalonso Thank you i passed to our devs, could you also test the camera in ASIStudio-ASIImg? please directly connect the camera to PC, don't usb any hub, and keep 12V power supply connected.
