Stronomer Is IR videography possible with ASI662 and if yes then at what wavelenghts?
Not with the existing camera window, which according to their manual, is an IR cut filter.
The UV/IR sealing window removable?
Yes. ZWO sells a D21 size clear anti-reflection coated (AR) glass window that you can replace the existing IR cut window with, if you want to do near-IR work.
https://cloudbreakoptics.com/products/zwo-protective-window-for-asi-cameras
https://agenaastro.com/zwo-d21-protective-dust-window.html
Does the optical window remove UV also besides IR?
In the past, ZWO's IR cut filters also cut UV, so I expect this one is the same.
Is there threads for 1,25" filter in the ASI662 camera body in front of imaging chip circular hole?
Yes, but you have to purchase separately. You first insert this ring all the way into the M42 thread of the camera:
https://cloudbreakoptics.com/products/t2-1-25-filter-adapter
https://agenaastro.com/zwo-t2-1-25-filter-adapter-t2-1-25-3.html
You then screw a 1.25" filter to it.
A M42 T2 tube then is screwed in over the filter, into the remaining M42 thread of the camera flange.
I often use this method to add a filter to my guide scope.
