ASIMount@ZWO is it possible for the AM5 to support variable slew rate (rightascensionrate/declinationrate) so that the popular satellite tracking software to instruct the mount to track in real time? Currently Skywatcher, AP, and other mounts support this feature.
In detail:
To
effectively	facilitate	continuous	tracking	a	few	capabilities	are	required;
• ASCOM	methods		“SetRightAscensionRate”	and	“SetDeclinationRate” are
available
• When	issuing	ASCOM	“GetRightAscension”	and	“GetDeclination”,	the	driver
must	return	live	time	position	data.		Some	drivers	only	update	the	position	at
timed	intervals.	For	example,	if	this	data	is	only	renewed	internally	once	a
second,	and	the	satellite	being	tracked	is	moving	at	2	degrees/second,
attempts to	point	could	be	off	by	2	degrees
• ASCOM	method	“SetPierSide”.	For	GEM	mounts,	when	slewing	with	variable
tracking	rates,	meridian	flip	commands	must	be	issued	by	the	software
