rimcrazy Now my EAF is totally bricked. It will not move at all.
If it is not completely bricked, and ASIAIR can still connect to it, check the Max Step Limit in the Focuser Setting window -- see if it has been set by the new firmware, in ZWO's infinite wisdom, to zero. If so, change it to 65000 to get the maximum movement range.
