I use my Asiair with two setups. When I change setup use, I must update the configuration values. With some equivalent soft (As NINA, sharpcap,...), it is possible to save all the setup configuration in a file. This file could be archived or use to reload the exact last configurations. It could be interesting to have this possibility with the ASIair Pro & Plus.
Thank you to have a look to my idea,
Kaelig
