sompi68 having a Celestron EdgeHD 8" myself, i can tell, that before attaching the EAF to the SCT, you need to manually bring the SCT into focus and then attach the EAF. And directly after attaching the EAF, set it's current position to 30.000, the minimum position to 0 and the maximum position to 60.000. This way, you have enough steps to move in both directions. Also, for SCTs it is best to set reversed in the EAF's settings in the ASIAir App to enabled because of gravity / mirror flop issues.
If you want to know more just search this forum – this topic came up several times.
Hth, Olli
