Hi there!! Anybody please could tell me which model of Shutter Release Cable is needed for connecting the ASIAir Plus to a Canon 700D(T5i)? Thanks!
Please... anyone can help?
Robjunkie Please check the Canon has the USB mini port or not. If not, try this one.
PMTeam@ZWO if you have a usb mini port what would be the cord to use?
What do you use if you do have a mini b port?
Skywatcher1 USB MINI to USB type A cable.
Tech@ZWO I’ve used both and neither connect but I have a canon 2000D any suggestions? Thank you for the response.
Skywatcher1 Please refer this to check your settings first, and test if the cable work fine if you connect your camera to PC.
