What drivers are needed for a 385MC connected to MacBook Pro
  • w7ay replied to this.
    rwebb55 What drivers are needed for a 385MC connected to MacBook Pro
    None, if you are just using an application.
    If you are building an application using ZWO's SDK, in addition to the libASICamera2.dylib, you will also need libusb.1.0.0.dylib.
    If you are building a Sandboxed application, be sure to also tick the USB entitlement under "Hardware."
    Thanks. Right now just beginning to learn. I'll stick to the basics for a while
    Write a Reply...
