Greetings,
My Asiair Plus has a broken micro SD card socket. It no longer latches when I put an SD card in. I had been using this as the image storage space since I got it and I think that the resultant insertions may have been too much for the little latch mechanism inside. I'm wondering if you can share the datasheet of the part (the SMD card slot) that you used for this? I'm fairly certain that I can replace it but without a suitable replacement part, I'll be stuck without an SD card slot.
Thank you 🙂
K
