Hello, love my AM5 mount and when I used the hand control unit to be in the home position the Dovetail head is not parallel to the mount body as its a bit off? I would think it would need to be, as every other mount I have is that way I can get the mount Polar aligned? Can someone please provide how to get it set using the "Calibrate Home Position feature".
Once I have the mount perfectly level I will use a bubble level to get the mount 90 & 0. I think that's right so it perfectly adjusted for Polar alignment. Any videos and a step by step would really be appreciated.. I know this feature resets the Dovetail plate but I want to be 100% sure that I do it correctly.Thank you I advance.
