Panama_Red When the time comes for the flip, a message pops up indicating the mount is slewing but, nothing happens.
By the way, this is actually "normal" for ASIAIR.
What is happening is that when it is time (according to the clock inside the ASIAIR) the target object has passed the Meridian, the ASIAIR will send a GOTO message to the mount.
If the mount's clock also agrees that the target is now on "the other side" of the Meridian, the mount will perform a Meridian flip, otherwise it will simply GOTO the object on the same pier side (i.e., make at most only a microscopic movement).
The message that you saw from ASIAIR simply means that it has sent a GOTO. It does not mean that the mount has actually slewed.
If the mount has really moved, ASIAIR will know, and then do the appropriate plate solving to recenter the object on the other side of the pier.
If the mount has not moved, a plate solve will indicate that the camera angle has not changed, and ASIAIR will then retry with the same GOTO command again after 1 minute.
ASIAIR will keep repeating the GOTO every minute until the mount finally performs a Meridian flip.
Now, if you are not properly star aligned, or your mount is not perfectly east-west leveled, the ASIAIR and mount "clocks" will be different. I.e., when ASIAIR thinks the telescope is pointed at the Meridian, the mount thinks the telescope has not yet reached Meridian.
Every 1 degree that your mount is not leveled against the horizon means that the "clocks" will be 4 minutes off in time . So, if your leveling is off by 1º, you may need to wait 4 minutes before all those GOTO commands finally succeed. 2 degrees off will cause you to wait 8 minutes in time, etc.
Thus, it is "normal" to have to wait a few minutes if (1) you did not do a multi-star aligment, or (2) your mount is not perfectly leveled, or (3) your polar alignment is off.
So, just wait, and eventually it will move. Eppur si muove.
Most people don't see this delay because they are already asleep, but again, it is "normal" unless you had done the above.
To compound the problem, ASIAIR also does not understand the concept of Daylight Saving Time. If the mount is observing DST, then you may need to wait an hour for the clocks to catch up. This is an ASIAIR bug that has existed since the very first version a couple of years ago. Since ZWO has not fixed it, people just resorted to lying to the mount that DST is not being observed. In this case, both clocks are off by 1 hour and everybody is happy (just don't time your dinner using the ASIAIR or the mount's clock in Summer).
So, be sure to also check the DST setting on your mount, and be sure to turn it off.
Fortunately, DST ends at the end of this month in Europe and a week after in North America (people in Arizona and parts of Indiana are lucky because they do not observe DST at all). And if DST is your problem, then it will solve itself in a couple of weeks time.
Remember though that even if DST has been disabled, you may still have to wait a couple of minutes (4 minutes for each degree that your mount is not leveled).
