Hi Everyone, I'm finding that my ZWO cameras, 3 so far and a 4th was planned, do not work well with TSX and my Paramount MX+ since no photos can be taken and I get 'Error 206' - something about a 'time-out'. I have read about 'lowering the bandwidth' somewhere in a ZWO driver but I cannot find out where to do that. So, I cannot use ZWO cameras with the MX+ and must consider another brand of CMOS camera unless someone has solved this same problem and could share their solution perhaps.
I have had some success using the camera but only if I bypass the mount's internal cabling and run a usb cable direct from the computer to the camera but this is clumsy, inelegant and subject to cable snags as I recently found out. It is not an acceptable solution I feel. Any help and suggestions would be much appreciated.
Gary
