Hello, is Asiair Plus compatible with the Servocat box from Stellarcat on Alt Az mount, I use servocat in conjunction with ArgoNavis.
Currently I use a ServoFi Wifi module which is connected directly to the Servocat box (not on ArgoNavis) and it works with SkySafari Pro in wifi without problem. I tried to connect with a USB / RS232 between Asiair Plus and servocat using LX200 and baud rate 9600, it does not work, I tried to connect USB / RS232 to serial 2 of the ArgoNavis ( config: Navis / baud rate 38400) by selecting Argonavis mount in Asiair it does not work either. Has anyone encountered this problem? Thanks in advance. Guillaume
