I assume asi air does not have a fuse on the 12v outputs, is that right? Im looking to do either inline fuses or a box like this
Ginsco 4 Way Fuse Block 4 Positon Quick Disconnect Fuse Panel Box with 5A 10A 15A 20A Blade Fuse Connectors Wrench Lables LED Indicator for Car Bus RV Truck Boat https://a.co/d/hwp7CG1
is there a better solution?
