All the features and the new UI once you get into the ASIAir app are great.. nice work there.
but I'm not going to stop pointing out the fact you broke the app on all iPads and everything is sideways and it messes with the iPad orientation flipping back and forth between landscape and portrait. You REALLY REALLY REALLY need to fix this app on iPad.. It's been called out at least 100 times by multiple people throughout the entire 20+ beta versions and you've ignored a major UI flaw and kept with a really bad UI design, the worst part is it's SOOOOOOO easy to fix, just have the app support landscape mode for the splash screen and first page on iPads.
The sequence right now is terrible
1.) Open app in landscape which is 100% of every ipad user, no one ever uses portrait on an ipad
2.) Splash screen is in a broken landscape visual, so this doesn't work
3.) ASIAir app then forces a rotation of screen so everything is crooked and you have to undock and rotate your ipad
4.) then enter device and the app rotates again from forced sideways portrait back to landscape
5.) you have to rotate your ipad again in order to use the app
6.) if you hit back button, or exit the app to check another app and then come back, you don't always go to device, so you end up in broken orientation again.
HORRIBLE HORRIBLE DESIGN.. FULL STOP... fix this.
