Sure, The issue is when you take 50 or 100 images, of 3-4 objects, they are all put in the same directory with the same file name. I am not sure which object is which without checking out each file (and group them by time). I do live stacking and EAA but then I take those images and stack them in postprocessing using different software. So putting the RA/DEC would make it easier to sort them.
The second request is so all the images are in a folder named for what that object is. It is strange to me the first object doesn't get a folder.
