=========================== USB Port17 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 2-17
Properties : 0x03
IsUserConnectable : yes
PortIsDebugCapable : yes
PortHasMultiCompanions : no
PortConnectorIsTypeC : no
ConnectionIndex : 0x11 (Port 17)
CompanionIndex : 0
CompanionHubSymLnk : USB#ROOT_HUB30#4&393adc3c&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 0x01 (Port 1)
-> CompanionPortChain : 2-1
========================== Summary =========================
Vendor ID : 0x03C3 (Unknown Vendor)
Product ID : 0x585B
USB Version : 3.0
Port maximum Speed : SuperSpeed
Device maximum Speed : SuperSpeed
Device Connection Speed : SuperSpeed
Self powered : no
Demanded Current : 512 mA
Used Endpoints : 2
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : ZWO ASI585MC Camera
Device Path 1 : \?\USB#VID_03C3&PID_585B#5&2ad60a6b&0&17#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Device Path 2 : \?\USB#VID_03C3&PID_585B#5&2ad60a6b&0&17#{c5b27530-3592-4e87-9e99-c2bafd5e5692}
Kernel Name : \Device\USBPDO-3
Device ID : USB\VID_03C3&PID_585B\5&2AD60A6B&0&17
Hardware IDs : USB\VID_03C3&PID_585B&REV_0000 USB\VID_03C3&PID_585B
Driver KeyName : {6bdd1fc6-810f-11d0-bec7-08002be2092f}\0000 (GUID_DEVCLASS_IMAGE)
Driver : \SystemRoot\System32\Drivers\ASICAMUSB3.sys (Version: 1.2.3.3 Date: 2021-12-03)
Driver Inf : C:\WINDOWS\inf\oem93.inf
Legacy BusType : PNPBus
Class : Image
Class GUID : {6bdd1fc6-810f-11d0-bec7-08002be2092f} (GUID_DEVCLASS_IMAGE)
Service : ASICAMUSB3
Enumerator : USB
Location Info : Port#0017.Hub#0002
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(17), ACPI(SB)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(SS01)
Container ID : {f620ede3-593b-11ed-9997-806e6f6e6963}
Manufacturer Info : ZWO
Capabilities : 0x84 (Removable, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend : 0
SelectiveSuspendEnabled : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState : 0
WakeFromSleepState : 0
Power State : D0 (supported: D0, D3, wake from D0)
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\03C3585B0000
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x11 (Port 17)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01 (Configuration 1)
Device Address : 0x08 (8)
Is Hub : 0x00 (no)
Device Bus Speed : 0x02 (High-Speed) -> not true, see below in Connection Information V2
Number Of Open Pipes : 0x01 (1 pipe to data endpoints)
Pipe[0] : EndpointID=1 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=1024 bInterval=0
Data (HexDump) : 11 00 00 00 12 01 00 03 00 00 00 09 C3 03 5B 58 ..............[X
00 00 01 02 00 01 01 02 00 08 00 01 00 00 00 01 ................
00 00 00 07 05 81 02 00 04 00 00 00 00 00 ..............
--------------- Connection Information V2 -------------
Connection Index : 0x11 (17)
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x04
Usb110 : 0 (no, port not supports USB 1.1) -> but Companion Port 2-1 does
Usb200 : 0 (no, port not supports USB 2.0) -> but Companion Port 2-1 does
Usb300 : 1 (yes, port supports USB 3.0)
ReservedMBZ : 0x00
Flags : 0x03
DevIsOpAtSsOrHigher : 1 (Device is operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 1 (Device is SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
Data (HexDump) : 11 00 00 00 10 00 00 00 04 00 00 00 03 00 00 00 ................
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x300 (USB Version 3.0)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x09 (9 bytes)
idVendor : 0x03C3 (Unknown Vendor)
idProduct : 0x585B
bcdDevice : 0x0000
iManufacturer : 0x01 (String Descriptor 1)
Language 0x0409 : "ZWO"
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "ASI585MC"
iSerialNumber : 0x00 (No String Descriptor)
bNumConfigurations : 0x01 (1 Configuration)
Data (HexDump) : 12 01 00 03 00 00 00 09 C3 03 5B 58 00 00 01 02 ..........[X....
00 01 ..
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x001F (31 bytes)
bNumInterfaces : 0x01 (1 Interface)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x40 (128 mA)
Data (HexDump) : 09 02 1F 00 01 01 00 80 40 09 04 00 00 01 FF 00 ........@.......
00 00 07 05 81 02 00 04 00 06 30 0F 00 00 00 ..........0....
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00 (Interface 0)
bAlternateSetting : 0x00
bNumEndpoints : 0x01 (1 Endpoint)
bInterfaceClass : 0xFF (Vendor Specific)
bInterfaceSubClass : 0x00
bInterfaceProtocol : 0x00
iInterface : 0x00 (No String Descriptor)
Data (HexDump) : 09 04 00 00 01 FF 00 00 00 .........
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0400 (max 1024 bytes)
bInterval : 0x00 (never NAKs)
Data (HexDump) : 07 05 81 02 00 04 00 .......
------ SuperSpeed Endpoint Companion Descriptor -------
bLength : 0x06 (6 bytes)
bDescriptorType : 0x30 (SuperSpeed Endpoint Companion Descriptor)
bMaxBurst : 0x0F (up to 16 packets per burst)
bmAttributes : 0x00 (The bulk endpoint does not define streams)
wBytesPerInterval : 0x0000
Data (HexDump) : 06 30 0F 00 00 00 .0....
---------- Binary Object Store (BOS) Descriptor -----------
bLength : 0x05 (5 bytes)
bDescriptorType : 0x0F (Binary Object Store)
wTotalLength : 0x0016 (22 bytes)
bNumDeviceCaps : 0x02
Data (HexDump) : 05 0F 16 00 02 .....
------------- USB 2.0 Extension Descriptor ------------
bDescriptorType : 0x10 (Device Capability Descriptor)
bDevCapabilityType : 0x02 (USB 2.0 Extension)
bmAttributes : 0x02
LPMCapable : 1 (Link Power Management protocol is supported)
BESLAndAlternateHIRD : 0 (BESL & Alternate HIRD definitions are not supported)
BaselineBESLValid : 0 (not valid)
DeepBESLValid : 0 (not valid)
BaselineBESL : 0
DeepBESL : 0
Data (HexDump) : 07 10 02 02 00 00 00 .......
----- SuperSpeed USB Device Capability Descriptor -----
bLength : 0x0A (10 bytes)
bDevCapabilityType : 0x03 (SuperSpeed USB Device Capability)
bmAttributes : 0x00
Bit 0 Reserved : 0x00
Bit 1 LTM Capable : 0x00 (no)
Bit 7:2 Reserved : 0x00
wSpeedsSupported : 0x0E (Full-Speed, High-Speed, SuperSpeed)
bFunctionalitySupport : 0x03 (lowest speed with all the functionality is 'SuperSpeed')
bU1DevExitLat : 0x0A (less than 10 µs)
wU2DevExitLat : 0x07FF (less than 2047 µs)
Data (HexDump) : 0A 10 03 00 0E 00 03 0A FF 07 ..........
-------------------- String Descriptors -------------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
Data (HexDump) : 04 03 09 04 ....
------ String Descriptor 1 ------
bLength : 0x08 (8 bytes)
Data (HexDump) : 08 03 5A 00 57 00 4F 00 ..Z.W.O.
------ String Descriptor 2 ------
bLength : 0x1C (28 bytes)
Language 0x0409 : "ASI585MC°°°°°" !ERROR contains 5 NULL characters
Data (HexDump) : 1C 03 41 00 53 00 49 00 35 00 38 00 35 00 4D 00 ..A.S.I.5.8.5.M.
43 00 00 00 00 00 00 00 00 00 00 00 C...........
This is the raport from the USB Device Tree Viewer
