@ASIAIR@ZWO#60236 thank you for the reply. I understand your position but you also must consider the mounts are way more expensive than the ASIAIR and people won’t replace the mount because it doesn’t work well ASIAIR.
I already read both the posts mentioned above and they talk about ASIAIR Pro which has SD card. ASIAIR Plus has the OS running on the eMMC. It makes it even harder.
I believe instead you can give the SSH access and users can modify the OS at their own responsibilities. If someone bricks it, it’s their problem. But you need to provide the SSH access.
