Testing my new AM5 mount. Running the new v2.0 ASIAir app and connecting via USB. After running it for a few hours inside tracking the sun, the mount no longer showed connected in ASIAir app. Had to connect to mount using Wi-Fi and AM5 app to reset home position. Only when restarting ASIAir Plus was mount able to reconnect. Not sure if it’s the new ASIAir software and/or mount causing the fault. Hopefully the cause is found and an update to fix this is released soon.
