I have a 290MC and I was trying to run it on Mac M1 with AsiCapture what is the setting to have max framerate? with 640x480 I reach 180 instead of 380 how can I change the BIT to 10?
stevesp
You can lower the exp time and reduce the resolution, turn on the hardware bin option, turn on high speed mode in Camera More Settings, and higher the USB bandwidth if it allows. and can I ask why you need that high framerate? Here is a post FYI. https://astronomy-imaging-camera.com/tutorials/what-configuration-gives-me-maximum-fps.html
Turn on high-speed mode and choose RAW8, then you will get 10bit, would you mind telling us why you need 10bit? https://astronomy-imaging-camera.com/manuals/ASI290_Manual_EN_V1.3.pdf
