Hi,
when slewing my AM-5 with high speed there is a clear difference in sound (or noise) depending on wheter the driver is started (connected) or not. Without the driver the sound is smooth. With the driver started there are perodic clicks and crackles in the noise the mount makes.
Listen to the two soundfiles I recorded and linked below..
They were recorded exactly in the same manner, the only difference is the started/closed driver. The slews were performed with the handcontroller with max speed. Both axes are moving at the same time.
https://soundcloud.com/mfender-244028682/am5-ascom-disconnected
https://soundcloud.com/mfender-244028682/am5-ascom-connected
Could other users of the mount tell me if this is normal?
Could someone from ZWO tell me what is going on here? It is VERY uncommon that the connection between a driver and a mount has an influence on the sound the mount makes when slewing. To me this sounds like a mechanical problem, not like normal operation.
