Hello,
I'm trying to build Dark Library for my guide cam (ASI174 MM), when ever I try to auto build the library it fails after 25%.
Can I manually build library and save it on ASIAIR either on the SD card (Plus version) or USB (Air Pro version), is there a specific location or folder where the library is stored?
Is there a process/steps for manually creating a dark library? Lastly does one need to create a library with different guide exposures and gain values?
Thanks in advance.
