Also happens in ASICap:
Translated Report (Full Report Below)
Process: ASICap [6180]
Path: /Applications/ASIStudio.app/Contents/MacOS/ASICap.app/Contents/MacOS/ASICap
Identifier: com.ZWO.ASICap
Version: ???
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-11-22 00:18:05.8512 +0100
OS Version: macOS 12.6.1 (21G217)
Report Version: 12
Anonymous UUID: CF2575B4-9690-49C3-8926-21B6A5B7FB76
Sleep/Wake UUID: E884523D-B0B9-4FA0-B241-8E084A02E8D4
Time Awake Since Boot: 54000 seconds
Time Since Wake: 7229 seconds
System Integrity Protection: enabled
Crashed Thread: 12
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Codes: 0x0000000000000001, 0x0000000000000008
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [6180]
VM Region Info: 0x8 is not in any region. Bytes before following region: 140722589581304
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
mapped file 7ffc87f6c000-7ffc885a8000 [ 6384K] r-x/r-x SM=COW ...t_id=9cebfbbf
Thread 0:: Dispatch queue: com.apple.main-thread
0 ??? 0x7ff898252940 ???
1 libsystem_kernel.dylib 0x7ff807d7897a mach_msg_trap + 10
2 libsystem_kernel.dylib 0x7ff807d78ce8 mach_msg + 56
3 CoreFoundation 0x7ff807e7b540 __CFRunLoopServiceMachPort + 319
4 CoreFoundation 0x7ff807e79bd0 __CFRunLoopRun + 1276
5 CoreFoundation 0x7ff807e79014 CFRunLoopRunSpecific + 562
6 HIToolbox 0x7ff810f965e6 RunCurrentEventLoopInMode + 292
7 HIToolbox 0x7ff810f9634a ReceiveNextEventCommon + 594
8 HIToolbox 0x7ff810f960e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
9 AppKit 0x7ff80a7e9fad _DPSNextEvent + 927
10 AppKit 0x7ff80a7e866a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
11 AppKit 0x7ff80a7dad19 -[NSApplication run] + 586
12 libqcocoa.dylib 0x10d260de3 0x10d22b000 + 220643
13 QtCore 0x10fa1993f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
14 QtCore 0x10fa1e932 QCoreApplication::exec() + 130
15 ASICap 0x1021a8a9a main + 4890
16 dyld 0x20258952e start + 462
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7ffc1f944 0x7ff7ffc1b000 + 18756
1 runtime 0x7ff7ffc2d3e0 0x7ff7ffc1b000 + 74720
2 runtime 0x7ff7ffc2ee58 0x7ff7ffc1b000 + 81496
Thread 2:: ImageShowThread
1 libsystem_kernel.dylib 0x7ff807d7b2be __semwait_signal + 10
2 libsystem_c.dylib 0x7ff807c8f863 nanosleep + 196
3 QtCore 0x10fa73e4b 0x10f834000 + 2358859
4 ASICap 0x1021811f2 ImageShowThread::run() + 66
5 QtCore 0x10f8560b3 0x10f834000 + 139443
6 libsystem_pthread.dylib 0x7ff807db54e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff807db0f6b thread_start + 15
Thread 3:: UIPopupHistogramThread
1 libsystem_kernel.dylib 0x7ff807d7f0aa poll + 10
2 QtCore 0x10fa7448a qt_safe_poll(pollfd*, unsigned int, timespec const*) + 90
3 QtCore 0x10fa75e87 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 903
4 QtCore 0x10fa1993f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
5 ASICap 0x1021654e7 SCommon::waitForMSec(int) + 55
6 ASICap 0x10211900a UIPopupHistogramThread::run() + 74
7 QtCore 0x10f8560b3 0x10f834000 + 139443
8 libsystem_pthread.dylib 0x7ff807db54e1 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff807db0f6b thread_start + 15
Thread 4:: com.apple.NSEventThread
6 AppKit 0x7ff80a9579ce _NSEventThread + 132
7 libsystem_pthread.dylib 0x7ff807db54e1 _pthread_start + 125
8 libsystem_pthread.dylib 0x7ff807db0f6b thread_start + 15
Thread 5:: cUSBDetectHotplug
5 ASICap 0x1021a767f cUSBDetectHotplug::run() + 335
6 QtCore 0x10f8560b3 0x10f834000 + 139443
Thread 6:: org.libusb.device-hotplug
6 CoreFoundation 0x7ff807f00567 CFRunLoopRun + 40
7 libusb-1.0.0.dylib 0x10ad4ddef darwin_event_thread_main + 399
Thread 7:
0 runtime 0x7ff7ffc3d814 0x7ff7ffc1b000 + 141332
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12 Crashed:
0 CoreFoundation 0x7ff807f4763a _CFGetNonObjCTypeID + 10
1 CoreFoundation 0x7ff807ea8358 CFRunLoopStop + 15
2 IOKit 0x7ff80a6d5e5e __IOHIDDeviceNotification + 195
3 IOKit 0x7ff80a69bcda IODispatchCalloutFromCFMessage + 318
4 CoreFoundation 0x7ff807ea826b __CFMachPortPerform + 288
5 CoreFoundation 0x7ff807e7baf1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41
6 CoreFoundation 0x7ff807e7b9d3 __CFRunLoopDoSource1 + 615
7 CoreFoundation 0x7ff807e7a047 __CFRunLoopRun + 2419
8 CoreFoundation 0x7ff807e79014 CFRunLoopRunSpecific + 562
9 libEFWFilter.dylib.1.7 0x10ac9f072 read_thread + 258
10 libsystem_pthread.dylib 0x7ff807db54e1 _pthread_start + 125
11 libsystem_pthread.dylib 0x7ff807db0f6b thread_start + 15
Thread 12 crashed with X86 Thread State (64-bit):
rax: 0x00007ff7518281d0 rbx: 0x0000000000000001 rcx: 0x000000010ac9ef50 rdx: 0x00007ff76181ac80
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x00000003087acfb0 rsp: 0x00000003087acfb0
r8: 0x00007ff7456ad2b0 r9: 0x0000000000000000 r10: 0x00000000ffffff00 r11: 0x00007ff7456ad2a8
r12: 0x00000003087acff0 r13: 0x00000003087acfe0 r14: 0x0000000000000000 r15: 0x0000000000000002
rip: <unavailable> rfl: 0x0000000000000243
tmp0: 0x00007ff8987be82c tmp1: 0x000000010ad22160 tmp2: 0x00007ff807ea8358
Binary Images:
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff807d77000 - 0x7ff807daefff libsystem_kernel.dylib (*) <0ea0d8ac-c27b-3a71-a59b-ec3a6f116acf> /usr/lib/system/libsystem_kernel.dylib
0x7ff807dfc000 - 0x7ff8082fcfff com.apple.CoreFoundation (6.9) <bddb824d-15df-3210-88e8-6aac5c154403> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff810f68000 - 0x7ff81125bfff com.apple.HIToolbox (2.1.1) <06fdecd6-9f69-397b-b1e2-a8226c0ba7ed> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff80a7ab000 - 0x7ff80b63afff com.apple.AppKit (6.9) <d2726161-3c3f-3b59-bd8d-4a088d4545ef> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x10d22b000 - 0x10d392fff libqcocoa.dylib (*) <aaf96c3b-7fa8-364b-9e1b-039f8d891422> /Applications/ASIStudio.app/Contents/MacOS/ASICap.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x10f834000 - 0x10fd69fff org.qt-project.QtCore (5.12) <4016188b-3e53-3268-95b9-a3826de2f323> /Applications/ASIStudio.app/Contents/MacOS/ASICap.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x10206c000 - 0x1022fffff com.ZWO.ASICap (*) <e0ce0509-3bed-363a-a9d1-05055d31cf5b> /Applications/ASIStudio.app/Contents/MacOS/ASICap.app/Contents/MacOS/ASICap
0x202584000 - 0x2025effff dyld (*) <7b87a986-a153-33c4-8470-d56410b7f9d5> /usr/lib/dyld
0x7ff7ffc1b000 - 0x7ff7ffc4afff runtime (*) <419e294c-6e25-389b-a0f2-b3d7c56a046e> /usr/libexec/rosetta/runtime
0x7ff807c7f000 - 0x7ff807d07fff libsystem_c.dylib (*) <e42e9d7a-03b4-340b-b61e-dcd45fd4acc0> /usr/lib/system/libsystem_c.dylib
0x7ff807daf000 - 0x7ff807dbafff libsystem_pthread.dylib (*) <b5454e27-e8c7-3fdb-b77f-714f1e82e70b> /usr/lib/system/libsystem_pthread.dylib
0x10ad42000 - 0x10ad53fff libusb-1.0.0.dylib (*) <a7c00eab-49c2-36bf-8aee-9fb694ba929b> /Applications/ASIStudio.app/Contents/Frameworks/libusb-1.0.0.dylib
0x7ff80a697000 - 0x7ff80a74cfff com.apple.framework.IOKit (2.0.2) <bcc679a9-324c-3d77-ad5d-d591befc73d5> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x10ac9b000 - 0x10ac9ffff libEFWFilter.dylib.1.7 (*) <3f489958-2c24-33af-b987-5450e3a85c0f> /Applications/ASIStudio.app/Contents/Frameworks/libEFWFilter.dylib.1.7
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 89
thread_create: 45
thread_set_state: 2
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 3520K 4
CG image 252K 23
ColorSync 224K 26
CoreAnimation 232K 14
CoreGraphics 12K 2
CoreUI image data 1980K 14
Dispatch continuations 64.0M 1
Foundation 16K 1
Kernel Alloc Once 28K 2
MALLOC 790.5M 87
MALLOC guard page 192K 10
MALLOC_MEDIUM (reserved) 800.0M 7 reserved VM address space (unallocated)
Rosetta Arena 4096K 2
Rosetta Generic 1108K 274
Rosetta IndirectBranch 1024K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 240K 24
Rosetta Thread Context 240K 24
STACK GUARD 20K 5
Stack 13.6M 12
Stack Guard 56.0M 7
VM_ALLOCATE 5728K 58
VM_ALLOCATE (reserved) 12K 2 reserved VM address space (unallocated)
__CTF 756 1
__DATA 23.8M 369
__DATA_CONST 14.4M 198
__DATA_DIRTY 637K 109
__FONT_DATA 4K 1
__LINKEDIT 710.3M 45
__OBJC_RO 82.8M 1
__OBJC_RW 3200K 3
__TEXT 293.8M 375
__UNICODE 592K 1
dyld private memory 1024K 1
mapped file 6.4G 851
shared memory 804K 14
unshared pmap 8512K 5
TOTAL 9.4G 2578
TOTAL, minus reserved VM space 8.6G 2578
Full Report
{"app_name":"ASICap","timestamp":"2022-11-22 00:18:07.00 +0100","app_version":"","slice_uuid":"e0ce0509-3bed-363a-a9d1-05055d31cf5b","build_version":"","platform":1,"bundleID":"com.ZWO.ASICap","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.6.1 (21G217)","incident_id":"C9E4D49C-3E57-4D09-9C95-5E7DBEFA03D3","name":"ASICap"}
"uptime" : 54000,
"procLaunch" : "2022-11-22 00:13:58.5944 +0100",
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro18,3",
"procStartAbsTime" : 1302886616533,
"coalitionID" : 3829,
"osVersion" : {
"train" : "macOS 12.6.1",
"build" : "21G217",
"releaseType" : "User"
"captureTime" : "2022-11-22 00:18:05.8512 +0100",
"incident" : "C9E4D49C-3E57-4D09-9C95-5E7DBEFA03D3",
"bug_type" : "309",
"pid" : 6180,
"procExitAbsTime" : 1308819700694,
"translated" : true,
"cpuType" : "X86-64",
"procName" : "ASICap",
"procPath" : "\/Applications\/ASIStudio.app\/Contents\/MacOS\/ASICap.app\/Contents\/MacOS\/ASICap",
"bundleInfo" : {"CFBundleIdentifier":"com.ZWO.ASICap"},
"storeInfo" : {"deviceIdentifierForVendor":"AE5B251C-912F-5538-9770-46AA09A81AC1","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.ZWO.ASICap",
"crashReporterKey" : "CF2575B4-9690-49C3-8926-21B6A5B7FB76",
"wakeTime" : 7229,
"sleepWakeUUID" : "E884523D-B0B9-4FA0-B241-8E084A02E8D4",
"sip" : "enabled",
"vmRegionInfo" : "0x8 is not in any region. Bytes before following region: 140722589581304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n mapped file 7ffc87f6c000-7ffc885a8000 [ 6384K] r-x\/r-x SM=COW ...t_id=9cebfbbf",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x0000000000000008","rawCodes":[1,8],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000008"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":6180},
"vmregioninfo" : "0x8 is not in any region. Bytes before following region: 140722589581304\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n mapped file 7ffc87f6c000-7ffc885a8000 [ 6384K] r-x\/r-x SM=COW ...t_id=9cebfbbf",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":45,"thread_set_state":2,"task_for_pid":89},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 12,
"threads" : [{"id":368870,"queue":"com.apple.main-thread","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":1},{"imageOffset":521536,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":515024,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":2},{"imageOffset":512020,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":2},{"imageOffset":189926,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":3},{"imageOffset":189258,"symbol":"ReceiveNextEventCommon","symbolLocation":594,"imageIndex":3},{"imageOffset":188645,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":70,"imageIndex":3},{"imageOffset":257965,"symbol":"_DPSNextEvent","symbolLocation":927,"imageIndex":4},{"imageOffset":251498,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1394,"imageIndex":4},{"imageOffset":195865,"symbol":"-[NSApplication run]","symbolLocation":586,"imageIndex":4},{"imageOffset":220643,"imageIndex":5},{"imageOffset":1988927,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":431,"imageIndex":6},{"imageOffset":2009394,"symbol":"QCoreApplication::exec()","symbolLocation":130,"imageIndex":6},{"imageOffset":1297050,"symbol":"main","symbolLocation":4890,"imageIndex":7},{"imageOffset":21806,"symbol":"start","symbolLocation":462,"imageIndex":8}]},{"id":368910,"name":"com.apple.rosetta.exceptionserver","frames":[{"imageOffset":18756,"imageIndex":9},{"imageOffset":74720,"imageIndex":9},{"imageOffset":81496,"imageIndex":9}]},{"id":368975,"name":"ImageShowThread","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":1},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":10},{"imageOffset":2358859,"imageIndex":6},{"imageOffset":1135090,"symbol":"ImageShowThread::run()","symbolLocation":66,"imageIndex":7},{"imageOffset":139443,"imageIndex":6},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":368976,"name":"UIPopupHistogramThread","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":32938,"symbol":"poll","symbolLocation":10,"imageIndex":1},{"imageOffset":2360458,"symbol":"qt_safe_poll(pollfd*, unsigned int, timespec const*)","symbolLocation":90,"imageIndex":6},{"imageOffset":2367111,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":903,"imageIndex":6},{"imageOffset":1988927,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":431,"imageIndex":6},{"imageOffset":1021159,"symbol":"SCommon::waitForMSec(int)","symbolLocation":55,"imageIndex":7},{"imageOffset":708618,"symbol":"UIPopupHistogramThread::run()","symbolLocation":74,"imageIndex":7},{"imageOffset":139443,"imageIndex":6},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":368983,"name":"com.apple.NSEventThread","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":1},{"imageOffset":521536,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":515024,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":2},{"imageOffset":512020,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":2},{"imageOffset":1755598,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":368993,"name":"cUSBDetectHotplug","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":32938,"symbol":"poll","symbolLocation":10,"imageIndex":1},{"imageOffset":2360458,"symbol":"qt_safe_poll(pollfd*, unsigned int, timespec const*)","symbolLocation":90,"imageIndex":6},{"imageOffset":2367111,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":903,"imageIndex":6},{"imageOffset":1988927,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":431,"imageIndex":6},{"imageOffset":1291903,"symbol":"cUSBDetectHotplug::run()","symbolLocation":335,"imageIndex":7},{"imageOffset":139443,"imageIndex":6},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":368994,"name":"org.libusb.device-hotplug","frames":[{"imageOffset":140705681189184,"imageIndex":0},{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":1},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":1},{"imageOffset":521536,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":2},{"imageOffset":515024,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":2},{"imageOffset":512020,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":2},{"imageOffset":1066343,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":2},{"imageOffset":48623,"symbol":"darwin_event_thread_main","symbolLocation":399,"imageIndex":12},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]},{"id":370430,"frames":[{"imageOffset":141332,"imageIndex":9}]},{"id":370466,"frames":[{"imageOffset":141332,"imageIndex":9}]},{"id":370472,"frames":[{"imageOffset":141332,"imageIndex":9}]},{"id":370473,"frames":[{"imageOffset":141332,"imageIndex":9}]},{"id":370474,"frames":[{"imageOffset":141332,"imageIndex":9}]},{"triggered":true,"id":370475,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13027168176},"r12":{"value":13027168240},"rosetta":{"tmp2":{"value":140703261426520},"tmp1":{"value":4476510560},"tmp0":{"value":140705686874156}},"rbx":{"value":1},"r8":{"value":140699998278320},"r15":{"value":2},"r10":{"value":4294967040},"rdx":{"value":140700469537920},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":13027168224},"rflags":{"value":579},"rax":{"value":140700201157072},"rsp":{"value":13027168176},"r11":{"value":140699998278312},"rcx":{"value":4475973456,"symbolLocation":0,"symbol":"hid_device_removal_callback"},"r14":{"value":0},"rsi":{"value":0}},"frames":[{"imageOffset":1357370,"symbol":"_CFGetNonObjCTypeID","symbolLocation":10,"imageIndex":2},{"imageOffset":705368,"symbol":"CFRunLoopStop","symbolLocation":15,"imageIndex":2},{"imageOffset":257630,"symbol":"__IOHIDDeviceNotification","symbolLocation":195,"imageIndex":13},{"imageOffset":19674,"symbol":"IODispatchCalloutFromCFMessage","symbolLocation":318,"imageIndex":13},{"imageOffset":705131,"symbol":"__CFMachPortPerform","symbolLocation":288,"imageIndex":2},{"imageOffset":522993,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__","symbolLocation":41,"imageIndex":2},{"imageOffset":522707,"symbol":"__CFRunLoopDoSource1","symbolLocation":615,"imageIndex":2},{"imageOffset":516167,"symbol":"__CFRunLoopRun","symbolLocation":2419,"imageIndex":2},{"imageOffset":512020,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":2},{"imageOffset":16498,"symbol":"read_thread","symbolLocation":258,"imageIndex":14},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":11},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":11}]}],
"usedImages" : [
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703260176384,
"size" : 229376,
"uuid" : "0ea0d8ac-c27b-3a71-a59b-ec3a6f116acf",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703260721152,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5246976,
"uuid" : "bddb824d-15df-3210-88e8-6aac5c154403",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1866"
"source" : "P",
"arch" : "x86_64",
"base" : 140703413207040,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 3096576,
"uuid" : "06fdecd6-9f69-397b-b1e2-a8226c0ba7ed",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "x86_64",
"base" : 140703304429568,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15269888,
"uuid" : "d2726161-3c3f-3b59-bd8d-4a088d4545ef",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2113.60.148"
"source" : "P",
"arch" : "x86_64",
"base" : 4515344384,
"size" : 1474560,
"uuid" : "aaf96c3b-7fa8-364b-9e1b-039f8d891422",
"path" : "\/Applications\/ASIStudio.app\/Contents\/MacOS\/ASICap.app\/Contents\/PlugIns\/platforms\/libqcocoa.dylib",
"name" : "libqcocoa.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4555227136,
"CFBundleShortVersionString" : "5.12",
"CFBundleIdentifier" : "org.qt-project.QtCore",
"size" : 5464064,
"uuid" : "4016188b-3e53-3268-95b9-a3826de2f323",
"path" : "\/Applications\/ASIStudio.app\/Contents\/MacOS\/ASICap.app\/Contents\/Frameworks\/QtCore.framework\/Versions\/5\/QtCore",
"name" : "QtCore",
"CFBundleVersion" : "5.12.9"
"source" : "P",
"arch" : "x86_64",
"base" : 4328964096,
"CFBundleIdentifier" : "com.ZWO.ASICap",
"size" : 2703360,
"uuid" : "e0ce0509-3bed-363a-a9d1-05055d31cf5b",
"path" : "\/Applications\/ASIStudio.app\/Contents\/MacOS\/ASICap.app\/Contents\/MacOS\/ASICap",
"name" : "ASICap"
"source" : "P",
"arch" : "x86_64",
"base" : 8629272576,
"size" : 442368,
"uuid" : "7b87a986-a153-33c4-8470-d56410b7f9d5",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "arm64",
"base" : 140703124533248,
"size" : 196608,
"uuid" : "419e294c-6e25-389b-a0f2-b3d7c56a046e",
"path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"source" : "P",
"arch" : "x86_64",
"base" : 140703259160576,
"size" : 561152,
"uuid" : "e42e9d7a-03b4-340b-b61e-dcd45fd4acc0",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703260405760,
"size" : 49152,
"uuid" : "b5454e27-e8c7-3fdb-b77f-714f1e82e70b",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4476641280,
"size" : 73728,
"uuid" : "a7c00eab-49c2-36bf-8aee-9fb694ba929b",
"path" : "\/Applications\/ASIStudio.app\/Contents\/Frameworks\/libusb-1.0.0.dylib",
"name" : "libusb-1.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703303299072,
"CFBundleShortVersionString" : "2.0.2",
"CFBundleIdentifier" : "com.apple.framework.IOKit",
"size" : 745472,
"uuid" : "bcc679a9-324c-3d77-ad5d-d591befc73d5",
"path" : "\/System\/Library\/Frameworks\/IOKit.framework\/Versions\/A\/IOKit",
"name" : "IOKit"
"source" : "P",
"arch" : "x86_64",
"base" : 4475957248,
"size" : 20480,
"uuid" : "3f489958-2c24-33af-b987-5450e3a85c0f",
"path" : "\/Applications\/ASIStudio.app\/Contents\/Frameworks\/libEFWFilter.dylib.1.7",
"name" : "libEFWFilter.dylib.1.7"
"sharedCache" : {
"base" : 140703257149440,
"size" : 19331678208,
"uuid" : "47e1dd7d-5e37-3ec3-a85c-901263ec66b5"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nCG backing stores 3520K 4 \nCG image 252K 23 \nColorSync 224K 26 \nCoreAnimation 232K 14 \nCoreGraphics 12K 2 \nCoreUI image data 1980K 14 \nDispatch continuations 64.0M 1 \nFoundation 16K 1 \nKernel Alloc Once 28K 2 \nMALLOC 790.5M 87 \nMALLOC guard page 192K 10 \nMALLOC_MEDIUM (reserved) 800.0M 7 reserved VM address space (unallocated)\nRosetta Arena 4096K 2 \nRosetta Generic 1108K 274 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 240K 24 \nRosetta Thread Context 240K 24 \nSTACK GUARD 20K 5 \nStack 13.6M 12 \nStack Guard 56.0M 7 \nVM_ALLOCATE 5728K 58 \nVM_ALLOCATE (reserved) 12K 2 reserved VM address space (unallocated)\n__CTF 756 1 \n__DATA 23.8M 369 \n__DATA_CONST 14.4M 198 \n__DATA_DIRTY 637K 109 \n__FONT_DATA 4K 1 \n__LINKEDIT 710.3M 45 \n__OBJC_RO 82.8M 1 \n__OBJC_RW 3200K 3 \n__TEXT 293.8M 375 \n__UNICODE 592K 1 \ndyld private memory 1024K 1 \nmapped file 6.4G 851 \nshared memory 804K 14 \nunshared pmap 8512K 5 \n=========== ======= ======= \nTOTAL 9.4G 2578 \nTOTAL, minus reserved VM space 8.6G 2578 \n",
"legacyInfo" : {
"threadTriggered" : {
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000544
"rolloutId" : "60186475825c62000ccf5450",
"factorPackIds" : {
"deploymentId" : 240000026
"experiments" : [
