OzScott I see lots of 2” tubes but not 54mm tubes.
You can always get them custom made by PreciseParts.com.
They can even fabricate an extension that has a "bolted" flange to match the screw holes of a couple of the ZWO EFW models. Be sure to test the backfocus first since the custom parts are not cheap. Don't just depend on numbers, test the backfocus at the corners of the frames (especially with the sensor size of a 6200 camera) with a real star field. The lead time is also rather long -- last time I ordered, it was between three and four weeks.
