ZWO's website notes that this (ASI432MM) 3rd generation Pregius sensor has much lower dark current (and correspondingly lower thermal noise) than the earlier generation ASI174MM Pregius sensor. As these are both uncooled sensors, can you provide data on dark current for the ASI432MM and the ASI174MM in electrons/pixel/second at typical operating temperatures, for example from O C to 30 C?
