enaiman My belief is the info is kept not by the EAF but by the software driving it.
It is likely saved in the EPROM of the microprocessor in the EAF, since you can set the parameters (current, max, fine and coarse steps) with ASIstudio and it will maintain the step position when the EAF is later connected to an ASIAIR.
(The internal temperature reading is most likely the sensor that are built into the microprocessors too ("free")).
