mrpugh55 I thought that 2 mainstream programs, Maxim and SkyX would be sufficient given I have at least 6 or 7 ZWO cameras operating correctly under these programs.
One way to prove that the camera is not completely dead is to use a short USB cable (and never a cable that is shipped with any of ZWO's products -- those are garbage), and connecting the camera to a Mac or Windows computer running one of ZWO's own software products, like one of the programs in their ASIstudio suite (not ASIAIR). At room temperature.
It is the only way to prove to ZWO/dealer that the camera is DOA, and that they need to replace it.
If it works with the latest ASIstudio, then your problem is caused by some software driver which ZWO provided to the other programs that created the problem (for example, an older driver that does not support a brand new camera like the ASI220).
If it works, but not with a longer cable, or when the temperature drops, then you have hit the ZWO marginal engineering lottery.
I think that @Swizerlan was just trying to help you narrow down the causes of the failure that you encountered.
