Tech@ZWO
My AsiAir Plus recently updated its firmware yesterday. I can connect to my CGX-L mount, but trying to slew with the arrow controls is sporadic. Sometimes it's non- responsive, sometimes moves too far with only one tap on the button. Also, when under the stars, it will find and sync to the 1st target and everything works fine. However, it loses it's position and exhibits very strange behavior if trying to center any target after the 1st. I have to turn off the mount and the AsiAir and start over each time. Finally, the merdian flip didn't work. Tried going to home position through the App, way off. I used the hand control to go to home, and that worked. Tried to continue the plan for the night, and it took 12 iterations for it to find the target. It will also take pictures while it's still slewing to a position, often 2 or 3 while it's still slewing. Hope there's an update to your software that fixes this soon.
