• ASIStudio
  • Asi 120 is disconnected when starting asi 183
Hello
I've juste bought an ASI 120 MM to guide a C11 and an ASI 183 MM for the imaging.
ASI 120 is connected to a Windows 10 PC in usb 2 with phd guiding, and ASI 183 MM is also connected to the PC in usb 3, using ASI Studio.
As soon as i start the 183 in ASIStudio, the 120 is immediatly disconnected from phd guiding.
Is there any way to make them run together?
    4 days later
    Grifiux
    Hello Grifiux, I've just tried 294MM for guiding and 178MM for imaging with your steps, but I can't reproduce the phenomenon you met, so could you please tell us more about how you use them?
      ASIStudio@ZWO
      We'd like to know the version of PHD2 / ASIStudio you use, and when you are using ASI183MM in ASIStudio, which software did you open? ASICap or ASIImg?
      Hello,
      I finaly reinstall the latest ZWO driver and phd2
      And now I'm able to connect an ASI 120 and A ASI 183 without ans issue.
      Thanks a lot for your time
      Write a Reply...
