Tech@ZWO
Thanks for responding. I can connect with your software and with Maxim. I also can connect with NINA.
The problem with Maxin and ACP is that after taking one guider picture, it hangs before taking a second. If I disconnect and then reconnect the camera, it will work.
The 174 worked fine for about 10-12 months then this came us as a problem. I have replaced the USB cables. They run into my 6200.
The Maxim people mention your driver with the errors found by the Conform software. I am not sure of the relevance, but I am in contact with them and the ASCOM Conform does come up with 6 errors. Here are the two that seem the most serious... see attachment for full listing:
14:28:21.600 StartExposure ERROR .NET - Exception: exception when reading ImageArrayASCOM.DriverException: CheckDotNetExceptions ASCOM.ASICamera2.Camera ImageArray Get System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. (See Inner Exception for details) ---> System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
--- End of inner exception stack trace ---
at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at Conform.CameraTester.CameraExposure(String p_Description, Int32 p_BinX, Int32 p_BinY, Int32 p_StartX, Int32 p_StartY, Int32 p_NumX, Int32 p_NumY, Double p_Duration, String p_ExpectedErrorMessage)
14:28:21.657 ImageArrayVariant ERROR .NET - Exception: exception when reading ImageArrayVariantASCOM.DriverException: CheckDotNetExceptions ASCOM.ASICamera2.Camera ImageArrayVariant Get System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. (See Inner Exception for details) ---> System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
As trouble shooting I have connected the camera directly to my computer to isolate the 174 from the 6200 hub. Unfortunately it is raining now, so it is hard to test the guiding on the bench without a proper setup of guide star and mount.
Any ideas appreciated, especially any updates or Beta versions of drivers that might be more advanced. The system is W10 and completely updated on a standard Dell mini desktop.
