I do some test tonight,first I make the mount roughly point north, then goto Jupiter, the Jupiter is not in field of eyepiece, then I slew it in the center of field, and click "Sync", then I goto "Rigel A", it is in the edge of field,
I also center it and sync, then goto Betelgeuse, do same. then Capella, moon. goto accuracy gradually improves.
The next goto will use the nearest position recorded.
