If I read this table correctly, it is not compatible using my Sky-Watcher Esprit 100 f:5.5 and Sky-Watcher Quattro 200 f:4? you mean with maximum that f-number must be bigger than that in table?
But if I use in same filter wheel with 31mm frameless filters, instead of 1,25" filters with frame, it IS compatible? both filters, 1,25" and 31mm, can be installed into that EFW....
