Hello,
Do you mean that the M54 tilt plate I mentioned can't replace the original M42 ?
I already saw the proposal you mention, however, it doesn't solve at all the issue or I missed something !
On the telescope side, again, I have no problem, I can use M48, however, on the camera side, even this 15mm M54 adapter can't be screwed to an M42 tilt plate !
Adding the M54M-M48F doesn't make any difference !
Tell me how you can screw a female M48 to a female M42 part and I'll get my answer !
Else, the M54 tilt plate screwed to the ASI 2600 MC pro in lieu of the M42 tilt plate, looks the ideal candidate provided that holes are positioned the same way as for the M42 stock tilt plate comining along with the AS 2600 MC pro !
I can't believe that a solution dsplayed has not been thought over !
Kind regards
Philippe
