aviola Can I somewhere find an image to download?
You can no longer explicitly download firmware to the third generation ASIAIR.
A "factory default" firmware resides in the eMMC storage. When you depress the RESET button for longer than 5 seconds, a copy of that eMMC firmware is then used as the active firmware.
You might try that. The next time the ASIAIR app connects to the device (assuming this fixes the problem), the app will update the very old firmware to the level that is required by the app.
(After that firmware reset, you will need to reset all of your WiFi settings, e.g., network password, etc, so don't willy nilly restore to that old firmware.)
However, your problem may not be firmware but hardware. First, remove everything except for 12V DC power INPUT and the LAN connections, to see if the ASIAIR boots up.
Next, the ASIAIR specs for power is bogus. I went through two different third-generation ASIAIR that will not boot if 12V DC exceeds 13.75 V, despite the specs stating that the DC input can be between 11 and 15V. So, check to make sure not only that DC is over 11V (with at least a 5A ability) , but that it is under 13.75V. Note that a fully charged sealed lead acid battery's voltage is 13.8 volts -- so are many industrial "12V DC" power supplies.
