Today the ZWO 294mm camera has been working fine, but for no reason it couldn't find the focus even with the moon, the whole screen is black without any record.
1.- I have uninstalled and installed the drivers
2.- I have tried the camera without telescope in different usb 3 ports
3.- In the same ports a zwo 462 camera works perfectly, that is, it makes noise
With the 294 you simply can't see anything, even showing a bright light you can't see anything at all.
-->> Sharpcap Previewing 0 frames (0 dropped)
I have tried to decrease the usb turbo usb min =40
-->> Windows 10, device manager, the camera appears and everything is ok. driver zwo
What is the solution?
Thank you
