SamoL What is the proper way to factory reset the Mini?
See if you can reset it the way you reset the larger ASIAIR. See if you can follow steps 1 through 5 of my recent post here (Post #5 in the thread):
https://bbs.astronomy-imaging-camera.com/d/15600-zwo-asi-air-plus-backup/5
In your case, after the 5 second reset, see if the ASIAIR is visible on WiFi.
You must first turn off ASIAIR. Then hold down the reset button while you power it on. And keep holding the reset button down for more than 5 seconds. After releasing the reset button, see if you can now see ASIAIR hotspot. If not, turn power off, and turn power back on and check again.
Can't you just get your dealer to send a replacement? And if they are willing, replace it with the larger model so you won't be stuck with ZWO's WiFi implementation (and not being able to change the WiFi channel, which is essential in a WiFi congested neighborbood).
