I am having a problem with my efw. I set it to slot 5 luminance then I went inside checked on my image after 15 minutes and it had switched to my quad filter 🤬😡🤬 so I manually switched it back and two seconds later it had switched back to the quad filter again. What is going on ? Is there some setting that I am missing to make it stay on the filter I choose? This is y first time using the EFW.
Any help is appreciated
Thanks
