Does your new PE200 pier extension allow for stacking 2 of them in use with the AM5 and TC40? I'm using the AM5 and TC40 with my AT130EDT F7 refractor, and raising the whole system by 200mm will help, but doubling that to 400mm would be just about perfect.
Would like the following:
1) to know whether mechanically using two of your pier extensions together is possible, and
2) your opinion on if it will significantly impact the stability for astrophotography. I'm asking this because using two of the PE200s together is mostly needed for comfort when I use telescope/mount for visual, but I also use the same system for AP.
Thx
